BACKGROUNDPLOT system variable
背景打印
Specifies whether background plotting is enabled for plotting and/or publishing. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: | 0 to 3 |
Default value: | 2 |
Possible options: |
0: None 1: 打印 (未支持) 2: 发布 |
