CMDLINEFRAMEUSETEXTSCR system variable
Command line frame TEXTSCR
When the Command line is floating, controls the effect of TEXTSCR command, also impacts log prompt delay. If on, displays a separate window, the same as in the docked state. If off, displays as a mini-frame.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t display (TEXTSCR) history window in a separate floating frame
On (1): Display (TEXTSCR) history window in a separate floating frame
