COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import or export is performed.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disables user interaction while import or export is performed.
On (1): Enables user interaction while import or export is performed.
