DELETEINTERFERENCE system variable
删除干扰
Specifies whether interferences between source and other 3d solids are retained or resolved (i.e. source solids will be subtracted from any interfering solids).
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t solve interferences after commands On (1): Solve interferences after commands |
