DIMATFIT system variable
箭头及文字填入
Specifies how dimension text and arrows are arranged when there is insufficient place within the extension lines. When DIMTMOVE=1, a leader is added if the dimension text is placed outside.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 3 |
Default value: | 3 |
Possible values: |
0: 文字和箭头都放到扩展线外侧 1: 先移动箭头,再移动文字 2: 先移动文字,再移动箭头 3: 视情况移动文字或箭头 |
