DMAUTOUPDATE system variable
3D 约束的重新计算模式
Specifies if a model automatically updates when 3D constraints are added or edited. If this setting is switched off, command DMUPDATE must be used to update the model.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t update 3D constraints automatically On (1): Update 3D constraints automatically |
