DRAWINGVIEWFLAGS system variable
Drawing View Flags
Enables the parallel generation and update of views created with the VIEWBASE command.
BricsCAD only
Type:
Short
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disabled parallel generation and update of views
On (1): Enabled parallel generation and update of views
