DRAWINGVIEWPRESET system variable
图形视图预置
Stores the current preset for the VIEWBASE command, the default value is 'None'. Presets specify the types of generated drawings and their placement in the layout.
BricsCAD only
Type: | String |
Saved in: | Registry |
Default value: |
None |
