DYNMODE system variable
动态输入模式
Turns dynamic input features on and off. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: |
-31 to 31 |
Default value: | 3 |
Possible options: |
Negative: Switch all off temporarily 0: No dynamic input 1: 指针输入打开(尚未支持) 2: 可编辑的动态标注 4: 跟踪动态标注 8: 通过 ucs x/y 轴动态标注最近的实体 16: 最近实体动态尺寸 |
