EDGEMODE system variable
边模式
Specifies how cutting and boundary edges are checked with the TRIM and EXTEND commands, with or without extension.
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
Possible values: |
Off (0): Use the selected edge without an extension On (1): Extend or trim the selected entity to an imaginary extension of the cutting or boundary edge |
