FILLMODE system variable
填实方式
Specifies whether multilines, traces, solids, hatches (including solid-fill), and wide polylines are filled in. If FILLMODE is off, all filled entities display and print as outlines, this will also reduce the time it takes to display or print a drawing.
Type: | Boolean |
Saved in: | Drawing |
Range: | On |
Possible values: |
Off (0): Entities are not filled On (1): Entities are filled |
