HOTKEYASSISTANT system variable
热键助理
Specifies whether to display the Hotkey Assistant widget or not.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: |
On |
Possible values: |
Off (0): Don’t show Hotkey Assistant widget On (1): Show Hotkey Assistant widget |
