INSUNITSDEFTARGET system variable
目标图形单位值
Specifies the target drawing units value if INSUNITS is zero. Values between 0 and 24 are accepted.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 24 |
Default value: |
0 |
Possible values: |
0: 未指定 (没有单位) 1: 英吋 2: Feet 3: Miles 4: Millimeters 5: Centimeters 6: Meters 7: Kilometers 8: Microinches 9: Mils 10: Yards 11: Ångströms 12: Nanometers 13: Microns 14: Decimeters 15: Decameters 16: Hectometers 17: Gigameters 18: 天文单位 19: Light-years 20: Parsecs 21: US Survey Feet 22: US Survey Inch 23: US Survey Yard 24: US Survey Mile |
