MECHANICALBROWSERSETTINGS system variable
Mechanical browser options
Sets the default mechanical browser options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 2047
Default value: 819
Possible options:
1: Expressions of constraints
2: Components parameters
4: Expressions of components parameters
8: Sub-components of standard parts
16: Arrays
32: Block and External References
64: Always synchronize selection
128: Keep values list order
256: Highlight objects selected in the browser
512: Asynchronous properties load
1024: Expose all solids
