PDFIMPORTAPPLYLINEWEIGHT system variable
套用轻量属性
Retains or ignores the lineweight properties of the imported entities.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Ignore the lineweight properties of the imported entities On (1): Retain the lineweight properties of the imported entities |
