PDFIMPORTUSEIMAGECLIPPING system variable
Clip images
Clips images during a PDF import. The clipped part images becomes transparent.
Note: Applies only if PDFIMPORTUSECLIPPING is on (1).
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Images are not clipped on import
On (1): Images are clipped on import
