PLINECACHE system variable
多段线缓存
Specifies creation of a cache of polyline vertices when a database file is opened.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: |
Off |
Possible values: | Off (0): Disable polyline cache On (1): Enable polyline cache |
