PROMPTOPTIONFORMAT system variable
Prompt option format
Controls how command options are displayed in the Command line.
A command option has a keyword, a description and a shortcut. The shortcut is the keyword without lower case characters (a-z).
For example, the third option of the CIRCLE command:
Keyword = TanTanRad
Description = Tangent-Tangent-Radius
Shortcut = TTR
Note: The PROMPTOPTIONTRANSLATEKEYWORDS system variable controls whether translations of command option keywords are loaded or not. If disabled, the local keyword will be a copy of the global (English) keyword. As a result global shortcuts can be used without an underscore.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 4 |
Default value: |
0 |
Possible values: |
0: Show description, with shortcut in upper-case 1: Show keyword only 2: Show description and keyword in brackets 3: Show description and shortcut in brackets 4: Show local keyword and global keyword in brackets (non-English versions only) |
Example for the CIRCLE command:
- Show description only (0)
- Select center of circle or [2 Point/3 Point/Tangent-Tangent-Radius/turn Arc into circle/Multiple circles]:Note: This is the default prompt option format in the English version. In other versions the default prompt option format depends on local standards.
- Show keyword only (1)
- Select center of circle or [2Point/3Point/TanTanRad/Arc/Multiple]:
- Show description and keyword in brackets (2)
- Select center of circle or [2 Point(2Point)/3 Point(3Point)/Tangent-Tangent-Radius(TanTanRad)/Turn arc into circle(Arc)/Multiple circles(Multiple)]:
- Show description and shortcut in brackets (3)
- Select center of circle or [2 Point(2P)/3 Point(3P)/Tangent-Tangent-Radius(TTR)/Turn arc into circle(A)/Multiple circles(M)]:
- Show local keyword and global keyword in brackets (relevant in localized versions only) (4)
