SAFEMODE system variable
安全模式
Specifies if executable code can be loaded and executed in the current session. Starting in a clean environment can help to eliminate potential causes of a crash.
只读
Type: | Boolean |
Saved in: | Not saved |
Default value: | Off |
Possible values: |
Off (0): Allows executable code run On (1): Does not allow executable code to run |
