SHOWDOCTABS system variable
选项卡可见性
Toggles showing of the document tabs On/Off. You can make the drawing area larger by hiding the document tabs from the user interface.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t make tabs visible On (1): Make tabs visible |
