SMDEFAULTSHARPBENDRADIUSLIMITRATIO system variable
Sharp bend radius limit ratio
Controls the default sheet metal sharp bend radius limit, as a ratio to the thickness.
Values between 0.0 and 1,000,000.0 are accepted
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Default value: |
5 |
