SMDEFAULTTABCLEARANCETYPE system variable
Tab clearance type
Controls if the SMDEFAULTTABCLEARANCEVALUE system variable is a ratio to the thickness or an absolute value.
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 1 |
Default value: |
0 |
Possible values: |
0: Thickness ratio 1: Absolute value |
