SMSPLITORTHOGONALBENDSPLIT system variable
Orthogonal bend split
Controls how a split that touches a bend is solved with the SMSPLIT command.
If on, the split direction for a bend is orthogonal to the bend axis (changes to a 90° angle as it passes through the bend). If off, the split direction is tangential to the split curve (does not change direction as it passes through the bend).
BricsCAD only
Type: |
Boolean |
Saved in: |
Drawing |
Default value: |
Off |
