SPATRIANGMODE system variable
三角模式
Triangulation mode identifies what portion of the mesh is to be triangulated. This variable is ignored if FACETRES is used. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 5 |
Default value: |
1 |
Possible values: |
0: 没有三角化 1: 全部三角化 2: 针对边界三角化 3: 三角化第一级栅格 4: Triangulate to 3 levels of fringe 5: 三角化至第四级 边 |
