STARTUP system variable
Startup
Specifies the display of the Create New Drawing and Startup dialog boxes.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 3 |
Default value: |
3 |
Possible values: |
0: Display the Select Template dialog box, or use a default drawing template file (set in the BASEFILE system variable) 1: Display the Startup and the Create New Drawing dialog boxes 2: Display the Start page 3: Display the Start page (with ribbon preloaded) |
