TEXTEDITMODE system variable
Text edit mode
Specifies whether text editing commands (DDEDIT) automatically repeat entity selection or not.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 2 |
Default value: |
0 |
Possible values: |
0: Multiple edit mode (command repeats until canceled) 1: Single edit mode (command ends after editing one text entity) 2: Automatic edit mode (single if editing preselected text, multiple otherwise) |
