TILEMODELIGHTSYNCH system variable
铺排模式光源同步
Specifies the synchronization of lighting in all model space viewports. (Internal use only)
Type: | Boolean |
Saved in: | Drawing |
Default value: | On |
Possible values: |
Off (0): Don’t synchronize lighting On (1): Synchronize lighting |
