UCSFOLLOW system variable
UCS 跟随
Specifies whether a plan view (A top view zoomed to extents) is generated automatically whenever the UCS changes. It is recommended to switch UCSDETECT off in this case.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t show plan view when changing UCS On (1): Show plan view when changing UCS |
