USECOMMUNICATOR system variable
使用Communicator
Indicates that a Communicator license was activated. If the license is changed, the new level comes into effect after restarting the program.
- 0: no license, Communicator import and export formats are not available.
- 1: trial, runs Communicator in trial mode, expiring after 30 days.
- 2: full, runs the full communicator import-export set.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 2 |
Default value: |
1 |
Possible values: |
0: Not using Communicator 1: Using Communicator Trial 2: Using Communicator |
