VTFPS system variable
查看转换最小FPS
Specifies the minimum FPS (frames per second) required for enabling animated view transitions. That is 7 by default, which means that the redraw time should take less than 143 (=1000/7) milliseconds. If the computer is not capable to redraw the view fast enough, no animation will be available.
Type: | Short |
Saved in: | Registry |
Range: |
1 to 30 |
Default value: |
7 |
