Dateitypen-Lexikon
The file types supported in BricsCAD are:
| CAD-Formate | Erweiterung | Beschreibung |
| FBX-Binärdatei | FBX | Mudbox format used to send 3D models to animation and rendering software; binary format creates compact files maintained by Autodesk; see the FBXEXPORT command. |
| FBX-ASCII-Datei | FBX | Mudbox format used to send 3D models to animation and rendering software; ASCII format creates human-readable files. |
| AutoCAD-Zeichnung | DWG | CAD drawing format created by Autodesk; to export drawings in an earlier version of DWG, use the SAVEAS command. |
| AutoCAD-ASCII-DXF | DXF | Drawing interchange format created by Autodesk; to create binary DXF files, use the DXFOUT command. |
| Zeichnungsvorlage | DWT | Vorlagen, auf denen neue Zeichnungen basieren. |
| 3D-DWF |
DWF oder DWFx |
CAD-Anzeigeformat für mit Autodesk erstellte 3D-Modelle. |
| Binäres DWF | DWF | Komprimierte Version von DWF; erstellt kompaktere Dateien. |
| Komprimierte ASCII-codierte 2D-Stream-DWF v6.0 | DWF | ASCII-Version von DWF komprimiert in einer ZIP-Datei. |
| Komprimierte DWF v5.5 | DWF | Compressed ASCII version of an older version of DWF; creates more compact files. |
| Binäres DWF V5.5 | DWF | Compressed version of an older version of DWF; creates more compact files. |
| ASCII DWF V5.5 | DWF | ASCII-Version einer älteren Version von DWF. |
| IFC-Datei | IFC | Saves a BIM model as an IFC file to use with an IFC-certified
applications data. BIM properties are included in the IFC
export. The Industry Foundation Classes (IFC) data model is intended to describe building and construction industry. |
| Unreal Engine | UDATASMITH | Exports BIM data to the Unreal Engine file type, which can be imported in the Twinmotion 3D architectural visualization program. |
| MicroStation DGN-Datei | DGN | MicroStation Designdateien. |
| SketchUp-Datei | SKP | SketchUp model files are imported as meshes. If desired, the CONVTOSOLID and CONVTOMESH commands provide easy conversion between meshes and solids. |
| Standarddatei | DWS | Drawing standards file, used by the STANDARDS and CHECKSTANDARDS commands. |
| Shape file | SHP | ESRI Shape file with support for GIS data types. |
| Vektorformate | Erweiterung | Beschreibung |
| Windows Meta File* | WMF | Vector format created by Microsoft; used by the Clipboard; see the WMFOUT command. |
| Enhanced Windows Meta File* | EMF | Aktualisierte Version von WMF. |
| Skalierbare Vektor-Grafiken | SVG | Wird von Webseiten zur Anzeige von Vektorgrafiken verwendet. Scalable Vector Graphics (SVG) is a family of specifications of an XML-based file format for describing two-dimensional vector graphics, both static and dynamic (e.g.. interactive or animated). The SVG specification is an open standard that has been under development by the World Wide Web Consortium (W3C) since 1999. |
| Lithografie | STL | Von 3D-Druckern verwendetes 3D-Format. STL (STereoLithography) is a file format native to the stereolithography CAD software created by 3D Systems. STL is widely used for rapid prototyping and computer-aided manufacturing. STL files describe only the surface geometry of a three dimensional object without any representation of color, texture or other common CAD model attributes. The STL format specifies both ASCII and binary representations. Binary files are more common, since they are more compact. Beachten Sie dazu auch den Befehl STLOUT. |
| Collada-Datei | DAE |
3D-Format, das von Rendering- und Animationssoftware verwendet wird. COLLADA (from collaborative design activity) is an interchange file format for interactive 3D applications. It is managed by the nonprofit technology consortium, the Khronos Group, and has been adopted by ISO as a publicly available specification, ISO/PAS 17506. |
| Dia-Datei | SLD | Proprietary graphics format created by Autodesk for saving screen grabs of viewports. |
| 3D-PDF** | Portable Document Format (PDF) is a file format used to represent documents, independently from application software, hardware, and operating system. |
| HTML-Format | Erweiterung | Beschreibung |
| HTML | HTM | Hyper Text Markup Language format files are opened in a Web browser. The VMLOUT command exports drawings to VML (short for vector markup language) embedded in a HTML file. |
| Wavefront Objektdatei | OBJ | A text file format which contains 3D graphic information such as vertices, normals, polygonal faces and 3D coordinates. Optionally, an .obj file can refer to a material (.mtl) file (which is also a text file) and the latter can refer to image or texture (.jpg/.png/.bmp) files. |
| Rasterformat | Erweiterung | Beschreibung |
| Bitmap* | BMP | Raster format created by Microsoft; used by the Clipboard. |
(*) The PICTUREEXPORTSCALE system variable sets the view size when exporting to picture formats (WMF, EMF, BMP).
(**) If the EXPORT3DPDFWRITER system variable is set to 1 - Internal 3D PDF writer, it is possible to export Mechanical Structure or exploded-view Animation.
Folgende Dateitypen werden in Communicator unterstützt:
| Standard für den Austausch von Produktdaten | STE, STP, STEP, STPZ | STEP (Standard for the Exchange of Product Data) is an ISO standard exchange format used for representing three-dimensional data in a format that can be recognized by multiple programs. |
| Initial Graphics Exchange Specification | IGS, IGES | A file format which defines a vendor neutral data format that allows the digital exchange of information among Computer-aided design (CAD) systems. |
| CATIA V4 | Modell | CATIA (Computer Aided Three-dimensional Interactive Application) is a multi-platform CAD/CAM/CAE commercial software suite developed by the French company Dassault Systèmes. |
| CATIA V5/V6 | CATPart, CATProduct, CGR | V5/V6 des Catia CAD-Programms von Dassault. |
| Parasolid |
XMT_TXT, XMT_BIN X_T, X_B |
Parasolid is a geometric modeling kernel originally developed by ShapeData, now owned by Siemens PLM Software (formerly UGS Corp.), that can be licensed by other companies for use in their 3D computer graphics software products. |
| VDA-FS | VDA | VDA-FS is a CAD data exchange format for the transfer of surface models from one CAD system to another. Its name is an abbreviation of Verband der Automobilindustrie - Flächenschnittstelle, which translates to the automotive industry association - surface data interface. The standard was specified by the German organization VDA. |
| Autodesk Inventor | IAM, IPT |
Autodesk Inventor, developed by U.S.-based software company Autodesk, is 3D mechanical CAD design software for creating 3D digital prototypes used in the design, visualization and simulation of products. Inventor uses specific file formats for parts (IPT) and assemblies (IAM). |
| Siemens | JT | JT is a 3D data format developed by Siemens PLM Software (formerly UGS Corp.) and is used for product visualization, collaboration, and CAD data exchange. It can contain any combination of approximate (faceted) data, boundary representation surfaces (NURBS), Product and Manufacturing Information (PMI), and Metadata (textual attributes) either exported from the native CAD system or inserted by a product data management (PDM) system. |
| Solid Edge | PAR, PSM | Solid Edge is a 3D CAD parametric feature solid modeling software. which provides solid modeling, assembly modeling and drafting functionality. |
| NX | PRT | PRT is a part or model file format used by PTC Pro/Engineer, which is a CAD program that creates design parts and assembly processes. |
Creo Elements Pro Engineer |
ASM, PRT | Parametric, integrated 3D CAD/CAM/CAE solution created by Parametric Technology Corporation (PTC). |
| Solidworks | SLDASM, SLDPRT |
SolidWorks is a 3D mechanical CAD program that runs on Microsoft Windows and is being developed by Dassault Systèmes. SLDPRT: Bauteildatei, SLDASM: Baugruppendatei The ImportSolidWorksRotateYZ system variable controls if geometry imported from SolidWorks files should be automatically rotated to map Y axis to Z axis. |
| 3D PDF* | Portable Document Format (PDF) is a file format used to represent documents, independently from application software, hardware, and operating system. | |
| ACIS | .asab, .asat, .sab, .sat | The 3D ACIS Modeler (ACIS) is a geometric modeling kernel developed by Spatial Corporation. |
| XCGM | .xcgm | Computer Graphics Metafile (CGM)-Dateiformatfamilie |
