Create a workflow
You can create a workflow:
  1. Click Workflows in the toolbar.
  2. Select the applicable workflow folder in the tool menu.
  3. Click Add workflow.
    The Add workflow window appears.
  4. Enter a name.
    Important: Every workflow name in a project must be unique.
  5. Define the coordinator role.
  6. If applicable, enter a description.
  7. Click Add to save the workflow.
    The Bricsys 24/7 Workflow Viewer opens.
  8. Follow the instructions in Design a workflow to create a workflow.
