Drag and drop the document(s) from your local device to the content pane.
Note: You can also first click on the file to open it and then drag and drop a new version of the file from File Explorer.
The Uploading window appears.
If applicable, add a status and a description per document.
Note: The available document statuses are: draft, proposal, in preparation, revised, and approved with remarks.
Note: If you first open the document and drag a file with the same extension from File Explorer, you can tick the option Rename to: to rename the document.
Note: If the file name already exists in the folder you want to drag and drop a file to, you can:
Tick the upload this document as a copy checkbox to upload the document as a separate file. If applicable, enter the required options.
Tick the Replace last revision checkbox to upload the document as a new revision.
Click Upload.
A pop up window shows the upload progress and informs you that the documents are successfully uploaded.
Tip: If you want to upload a lot of documents simultaneously, you can use the Bricsys 24/7 Transfer Tool.
