Projects list
The projects list displays when opening the mobile app on your mobile device.
- Tap BY ORGANISATION to list the projects by organisation.
- Tap ALPHABETICAL to list the projects alphabetically.
To open a project from the list, choose between these actions:
Tap a project in the list.
Enter a project name in the search bar.
Tap a project in the filtered project list.
The project opens.
Note: If the project administrator has enabled two-factor authentication for the project, you need to enter a token from your token card to log in to the project.
Note: When you're inside a project, tap
to return to the projects list.
