Inform project members about an update by sending a notification.
Select one of the applicable tools in the toolbar: Files, Tasks, Workflows or Forms.
Select the applicable folder, document, task, workflow or form in the tool menu or content pane.
- Click Send notification, or click the ellipsis button
and click Send notification in the context menu.
The Message window appears.
Add the recipients in the To field.
If applicable, edit the Subject.
Write a message.
Click .
A pop up window informs you that the notification is sent. The recipients will receive an email with your message.Note: You can edit your notification preferences in Profile settings.
