ALIGNMENTLINE command
Creates unconstrained line element between two specified points on existing or on a new Horizontal Alignment.
Icon:
Method
There are two options:
- Create a new line element between two specified points on existing horizontal alignment.
- Create a new alignment by drawing a line element between two specified points.
Options within the command
- Select existing horizontal alignment
- The new unconstrained line element is created on selected existing Horizontal Alignment, between two specified points.Note: First select the existing horizontal alignment in the drawing, and then specify the first and second point, between which a new line element is created. You can then continue drawing new line elements on existing horizontal alignment until you press the Enter key.
- Create new alignment
- Creates new Horizontal Alignment by drawing a line element between two specified points.Note: Specify the first and second point in the drawing, between which a new line element is created. You can continue drawing new line elements until press the Enter key.
