PARAMETERSPANELOPEN comando
Opens the Parameters Manager panel.
Icono:
Descripción
Opens the Parameters Manager panel to display it in the current workspace. The Parameters Manager panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Parameters Manager panel can be either floating, docked or stacked.
