Arranges the entities draw order based on their index color via the command line.
Options within the command
- Draworder
- Changes the display order of the selected entities using the DRAWORDER command.
- Enter color numbers separated by comma
- Allows you to specify the colors indexes, separated by comma.
Note: The first color places the entities in the front, while the last color places the entities in the back.
- Enter draworder location for objects
- Allows you to choose between Front and Back.
- Front
- Places the selected entities in front of the entities that are not specified in the color list.
- Back
- Places the selected entities behind the entities that are not specified in the color list.
- Redefine order for selected blocks?
- Changes the display order of the entities in blocks.
- Y
- The selected blocks are reordered.
- N
- The selected blocks remain unchanged.
- Handles
- Changes the display order of the selected entities by reordering entities in the drawing database.
