-COPYTOLAYER command (Express Tools)
Copies entities to another layer.
Creates duplicates of selected entities on a specified layer. You can specify a different location for the duplicated entities.
Options within the command
Lists the available layer names.
Allows you to select an entity with the necessary layer name.
return
Creates the copies in the same location as the selected entities.
