-DGNEXPORT command
Exports the current drawing to MicroStation DGN File (*.dgn) format in the command line.
Method
Specify the full path and file name for the exported DGN file.
Note: Type ~ (tilde) to display the Export Drawing As dialog box, which allows you to specify the folder and the name for the DGN file.
Options within the command
DGN
Converts reference to DGN.
DWG
Keeps reference to DGN.
Bind
Binds reference file to the parent DGN.
Detach
Detaches external reference.
