EXPORT command
Exports data from the current drawing to a variety of file formats.
Icon:
Alias: DWFOUT, EXP
Opens the Export Drawing As dialog box to save the data from the current drawing to a variety of file formats.
These are the supported file formats for export, depending on the license level:
- BricsCAD Lite
- FBX binary file (.fbx)
- FBX ASCII file (.fbx)
- AutoCAD Drawing (dwg)
- AutoCAD ASCII DXF (dxf)
- Drawing Template (.dwt)
- Bitmap file(2) (.bmp)
- Windows Meta File (.emf)(1) (2)
- Enhanced Windows Meta File (.wmf)(1) (2)
- 3D DWF v6.01 (.dwf)
- Binary DWF v6.0 (.dwf)
- Zipped ASCII Encoded 2D Stream DWF v6.0 (.dwf)
- Compressed DWF v5.5 (.dwf)
- Binary DWF v5.5 (.dwf)
- ASCII DWF v5.5 (.dwf)
- Compressed DWF v4.2 (.dwf)
- Binary DWF v4.2 (.dwf)
- ASCII DWF v4.2 (.dwf)
- XPS DWFx (.dwfx)
- Scalable Vector Graphics (.svg)
- Lithography (.stl)
- Collada file(.dae)
- Micro Station DGN File (.dgn)
- BricsCAD Pro
- Unreal Datasmith (.udatasmith)(1) (2)
- Rhino file (.3dm)(1) (2)
3D PDF: .pdf
- Assembly ACIS file (.asat)
- Assembly ACIS file (.asab)
Note: Native export to 3D PDF and ASAT formats also support mechanical blocks, external references and solids.Note: EXPORT stores a scale factor in the SAT and SAB files relative to mm which will be used to scale while IMPORT, and creates the current SPATIAL ACIS format which cannot be imported into AutoCAD®.
- BricsCAD BIM / Mechanical / Ultimate
- IFC2x3 file (.ifc)
- IFC4 file (.ifc)
- IFC4x1 (.ifc)
(1) Not available for BricsCAD for Linux.
(2) Not available for BricsCAD for macOS.
Choose an animation to export (1) and set the required number of frames per second (fps) (2), or select No exploded view animation to export the document without animation.
The import and export procedures using Communicator are controlled through a series of user preferences. See the Communicator section in the Settings dialog box.
