-LOGINUSAGEDATAPROGRAM command Opens the Login dialog box. Description Note: If you are already logged in, a login warning message displays. Press OK to continue. Parent topic: Riferimento ComandiRelated variablesUSENEWRIBBON system variableRelated informationAssistente I.A.Programma Utilizzo Dati di BricsCADFinestra di dialogo Login
