-OVERKILL command
Deletes duplicate and overlapping entities and combines duplicate blocks.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Deletes duplicate entities and overlapping lines, arcs, and polylines, and unifies partly overlapping or contiguous ones. Optionally moves duplicates to a dedicated layer.Combines duplicate blocks and optionally purges duplicate block definitions.
Options within the command
- Done
- Executes the overkill procedure.
- Ignore
- Sets the properties to ignore.
- None
- Properties are taken into account to determine if overlapping entities should be combined.
- All
- All properties are taken into account.
- Color, etc.
- The colors of overlapping entities are considered. If the colors match, then they are combined or deleted.
- TOlerance
- Sets the tolerance for the comparison process.
- optimize Plines
- Segments of selected polylines are evaluated individually, duplicate vertices and segments are removed. If lines or arcs duplicate a polyline segment, one of them is deleted, which might break a polyline.
- segment witDth
- Specifies if the width property of polyline segments is ignored.
- Break polyline
- Polyline segments are kept intact even if the duplicates are deleted.
- Yes
- Optimizes polyline entities.
- No
- Polyline entities are not optimized.
- combine parTial overlap
- Partially overlapping entities are unified into a single entity.
- combine Endtoend
- Collinear lines and polyline segments having coinciding endpoints are unified into a single entity or segment.
- Associativity
- Associative entities are not processed.
- delete or Move duplicates
- Determines what to do with duplicate entities.
- Move
- Entities are moved to Overkill Layer.
- Combine duplicate block definitions
- Searches the drawing for duplicate block definitions and replaces all such block instances by the most recent of these duplicates.
- Purge duplicate block definitions
- Deletes duplicate block definitions.
