-PUBLISH command
Prints the content of a DSD file.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Prints the content of a Drawing Set Description (*.dsd) file at the Command line.
Note: Create the .dsd file with the PUBLISH command. The .dsd
file specifies the file name, layouts, page setups, plotter and printer names,
orientation, plot scale, number of copies, optional plot stamp, and the order in
which to plot the files.
Note: This command adds a watermark to publish output obtained using an Academic license.
Method
Select a .dsd file in the Select Sheet List dialog box.
Note: If the BACKGROUNDPLOT system variable is 2 or 3, the
sheets are printed in the background.
