AMPOWERDIM_ALI command
Creates aligned linear dimensions.
Icon:
Creates aligned linear dimensions. This command is a shortcut to the Linear Aligned option of the PDIM command.
Methods
Define the two extension lines and specify the location of the dimension. The Edit Dimensioning dialog box opens to define the parameters of the dimension.
After the aligned linear dimension is created, you can define new dimensions by choosing PDIM command options.
