AMPOWERDIM_ANG command
Creates angular dimensions.
Icon:
Creates angular dimensions. This command is a shortcut to the Angular option of the PDIM command.
Methods
There are three methods to define the angle:
- By defining the three points.
- By defining the two lines.
- By defining an arc or a circle.
The Edit Dimensioning dialog box opens to define the parameters of the dimension.
After the aligned linear dimension is created, you can define new dimensions by choosing PDIM command options.
