AMPOWERDIM_RAD command
Creates radial dimensions for arcs and circles.
Icon:
Alias:
Creates radial dimensions for arcs and circles. This command is a shortcut to the Radial Radius option of the PDIM command. It automatically adds a radius symbol to the dimension text.
Methods
Select the arc or the circle and the location of the dimension line.
The Edit Dimensioning dialog box opens to define the parameters of the dimension.
After the aligned linear dimension is created, you can define new dimensions by choosing PDIM command options.
