AMPOWERDIM_ROT command
Creates rotated linear dimensions.
Icon:
Alias:
Creates rotated linear dimensions. It measures the distance between two points in a direction that is at an angle to a line connecting the two points. This command is a shortcut to the Linear Rotated option of the PDIM command.
Methods
Select two extension points, define the angle of the dimension line, and the location of the dimension line.
The Edit Dimensioning dialog box opens to define the parameters of the dimension.
After the aligned linear dimension is created, you can define new dimensions by choosing PDIM command options.
