AMPOWEREDIT command
Identifies the selected entity and executes the most relevant command to edit it.
The AMPOWEREDIT command identifies any entity you select and executes the most appropriate command to edit it. For example, if you run the command and select a dimension entity, the Edit Dimensioning dialog box opens.
