ARC command
Creates an arc.
Icon:
Alias: A
Creates an arc from a combination of options including the start point, second point, end point, center, included angle, direction, and length of chord.
- Start
- Direction
- Second
- Radius
- Length of chord
- Angle
- Center
- End
Methods to create an arc
This command has 3 methods to begin creating an arc:
- Start of arc
- Center
- Follow last point
You can press the Ctrl key while drawing an arc to change its direction from counterclockwise to clockwise.
- Start of arc
- Begin creating an arc by specifying a start point then:
- Second point
- Specify a point along the arc’s circumference.
- End
- Specify the end point of the arc.
- Center
- Begin creating an arc by specifying a center point then:
- Start
- Specify the start point of the arc.
- End
- Follow last point
- Begin creating an arc from the last drawn arc or line segment, following its angle, then:
- End
- Specify the end point of the arc. The arc is drawn tangent to the previous segment.
- Last point
- End of arc
Additional options within the ARC command
After you begin creating an arc, the following options may be available:
- Angle
- Specify the included angle of the arc.
- Direction
- Specify the direction of the arc.
- Radius
- Specify the radius of the arc.
